Technical problem while transferring from another provider to Fizz cell phone
jmorin
jmorin Posts: 2 ✭✭
edited October 2024 in Your Fizz Account
During the activation of my new SIM card I received a notice of a technical issue. 8 hours and still waiting for an update. I the meantime I am without a cell phone.
How can I contact someone for an update.
    elena code xzi4t Posts: 14,725 ✭✭
    edited July 2024
    Hi @jmorin
    Did you contact the support?
    To contact the support, https://fizz.ca/en/support , and click on the green bubble on the bottom right of the page in order to chat with them to find the right solution for you.
    wenhan Posts: 2,670 ✭✭
    you shouldn't be without a cell phone plan. your old fido plan should not be cancelled unless the transfer goes through. when you log into your fizz account at the top notification it should show if they have an issue and you can see what it says to do.
    Whizz Posts: 29,276 admin
    Hello jmorin  ,
    Sorry to hear about the issue!
    I verified your account and it appears that there was a delay in the transfer process, which took a bit longer than initially expected.
    But after verifying the account I saw that the transfer has been completed and the service should be up and running.
    Please reboot your phone, enable / disable airplane mode and test the line using these details : https://fizz.ca/en/faq/how-test-my-fizz-line
    Have a good one,
    -Raul, Community Moderator
