Will Xiaomi Redmi note 12 Pro will work with fizz mobile?
luis2929
luis2929 Posts: 1 ✭✭
edited August 2023 in My Mobile
Xiaomi Redmi note 12 Pro, Global ROM Redmi Note 12 Pro
There is an Aliexpress summer sale, and I am planning on buying Xiaomi Redmi note 12 Pro. Will it compatible with fizz mobile?
I am checking this page : https://www.kimovil.com/en/frequency-checker/CA/xiaomi-redmi-note-12-pro (all operators)
Network -------- Full Netcom, Dual SIM Dual Standby
5G:n1/n3/n5/n8/n28A/n38/n41/n77/n78
4G:FDD-LTE:B1/B3/B5/B8/B19, TDD-LTE:B34/B38/B39/B40/B41, Lte B41(2496-2690194MHZ)
3G:WCDMA:B1/B5/B6/B8/B19;CDMA EVDO:BC0
Best Answer
    Jess_i88b6 Posts: 16,361 ✭✭
    Answer ✓
    hi @luis2929
    From the specs that you posted, is missing the B4 for the LTE, therefore, without that you will have problem using the DATA therefore the VoLTE too
    An LTE compatible phone configured with LTE network preferences must support:
    The HSPA 850 MHz frequency for calls.
    The dual frequency 1700/2100 MHz (also called AWS or band IV) for mobile data.
    A phone that only allows 3G configuration or HSPA network preference must support:
    The dual frequency 1700/2100 MHz (also called AWS)
    When you buy a new phone, the supported frequencies are usually listed in the technical specifications. If not, do a search on the Internet. There are sites that will confirm the frequencies supported by your phone once you enter its IMEI in their search engine.
    source: https://fizz.ca/en/faq/compatible-devices
