Speed slower since Videotron outtage of febuary 12 2021... anyone else speed has recently reduced?
Mélissa E.
in Internet
Speed slower since Videotron outtage of febuary 12 2021... anyone else speed has recently reduced? I have the 60 Mbps Plan. I always had steady 60 mbps download speed or better. Now, it went down to something between 45-55 mbps. Anyone recently experienced this ? Router has been rebooted and speed had been tested with multiple speed test from multiple devices. Thanks.
10
Hi Mélissa
Have you tried factory resetting of the modem? And then connect only 1 device via ethernet cable to run the speedtest.
If there is no improvement, please feel free to contact Fizz support: https://fizz.ca/en/contact-us5 -
Turbo speed over here.. no problem at all3
Even better than what i paid for for me (130 instead of 120
) . So no problem. You can restard your routeur but do you changed your DNS when the problem append with the videotron DNS ? Have a nice day
3 -
No issue here, your best bet might be to contact fizz support team directly. I usually like to contact them through facebook messenger3
I would try to use a vpn to see how it works. Sometimes it helps3
Videotron's outage was related to their DNS service (which is some kind of telephone directory but for numeric IP and website names, like 104.18.29.99 = www.fizz.ca) .
To make this simple, it works or not. It cannot be a speed issue.
Though few hours later it was fixed.
Now, if you mitigated the issue (like using a VPN, changing to a different DNS server, or what not), then you might to review that fix. But even then it would not affect by THAT much.
Hope this helps narrowing it down.4 -
Nothings changed in my setup. Rebooted the modem multiple times since and nothing changed. No dna change, no vpn.
Videotron outtage is probably a pure coincidence but i used to have the speed i paid for for the last 2 years and now i don't.3
