is static ip possible ?
I need to give my IP to access a server and after 2 days My ip address change. I want to have a static IP. Is it possible ?
    Whizz Posts: 29,249 admin
    Hello Martin,
    Our network is configured in such a way that public (external) IP addresses are dynamic and change by themselves from time to time.
    On the other hand, given the low number of public IP addresses available due to the multiplication of Internet connections and connected devices in general, these addresses remain increasingly assigned to the same members.
    One solution for you might be to set up a VPN network that would be used to hide or change your IP address manually. Another solution could be to completely unplug your Fizz Wi-Fi modem for several hours or a few days (electric cable and coaxial cable). When restarting, the modem might pick up a different IP address. However, there is no guarantee that this will be the case.
    If you need anything else, we are available between 8 am and 9 pm everyday or any time at https://fizz.ca/en/contact-us
    Have a great day!
    Adelina
