Going throught a critical phase, no more data until 17june and I depend on it for work, help!!
fpmeun
fpmeun Posts: 9 ✭✭
edited June 2025 in Data Gifting
Hello to anyone reading this, im in need until my new plan gets renewed the 17! I urgently need this as I have none anymore and depending on it for work, doordash and instacart. Any amount will be greatly appreciated thank you so very much in advance.
Frankee
REFERENCIAL CODE: CF9AF
    ttify_NHJA5 Posts: 2,071 ✭✭
    I’ll send you some
  • fpmeun
    fpmeun Posts: 9 ✭✭
    @ttify said:
    I’ll send you some
    Thank you so very much , very greatly appreciated <3
    Mark123_2024 Posts: 10,266 ✭✭
    I'll send you some data.
  • 40QE_2024
    40QE_2024 Posts: 435 ✭✭
    popfizz_MFHPF Posts: 1,704 ✭✭
    Sent you a little bit
  • fpmeun
    fpmeun Posts: 9 ✭✭
    Thank you everyone, I have no words how I appreciate each and everyone of you! THANK YOU
  • Krashr
    Krashr Posts: 6 ✭✭
    Sent you 5GB, hope it helps with your work and holds you until the 17th!
  • fpmeun
    fpmeun Posts: 9 ✭✭
    Oh wow thank you so so very very much. <3 And each and everyone of you thank you for your generosity, it is so appreciated! Bless y'All o:)
  • zarazara
    zarazara Posts: 27 ✭✭
    Send you 1GB. Take care.
  • zarazara
    Send you an extra 5GB. Take care.
