Do I pay for incoming calls if I dont have a "unlimited minutes" plan
jeanpaul152
Posts: 2 ✭
Hello, I would like to take a phone plan for calls to only receive calls. If I do not take "unlimited minutes" when creating the plan, will I have to pay fees if I do not have a plan for minutes?
2
Best Answer
Hi @jeanpaul152
Without unlimited minutes, you will not be able to receive calls. You need to either purchase an add-on or add funds to your Fizz wallet (available in certain provinces).
With the Fizz wallet, you will be charged per minute, rounded up to the next minute for both outgoing and incoming calls.
Articles
1
Yes you will have to buy add-ons to receive or call someone.
1 -
yes with add-on or wallet if available
1 -
It's simpler with unlimited calls because it's always the same cost, what helps to make a budget are the fixed costs so no surprises
0 -
incoming call is not free.
1
