Why does my phone keep switching from lte to lte+
jonathan L. 3175
jonathan L. 3175 Posts: 10 ✭✭
edited October 2023 in My Mobile
Why doesn't it stay on lte+
Best Answer
    Jess_i88b6 Posts: 16,393 ✭✭
    edited October 2023 Answer ✓
    Hi @jonathan L. 3175
    That it can be a signal problem, it can be that you are between two or more bridges with almost the same level and the phone change the connection.
    You can find an app to see with bridge are you using, I believe that one of them is called Network Signal info
    For sure LTE+ has a theoretical speed higher than LTE, but you will be ok in LTE. If I remember correctly one is 100mbps the other 300mbps, but I can remember wrong
