Do you have solution to fix my problem
Etienne B. 53595
Etienne B. 53595 Posts: 1 ✭✭
edited September 2024 in Break Room
I Work in Nunavut Canada, and need to put my phone in wifi call but does’nt have option
  • EricPD
    EricPD Posts: 188 ✭✭
    Fizz doesn’t support VoWIFI yet. Probably once VoLTE is available, but definitely not before.
    Andrei_ref_R7VK1 Posts: 13,883 ✭✭
    VoLTE will be available somewhere in 2023, hopefully VoWIFI will be activated as well.
  • Mataze
    Mataze Posts: 2,070 ✭✭
    Hi @Etienne B. 53595
    I suggest you to use different app like messenger, facetime, Whats'App, skype, zoom, google meet in order to use the Wi-Fi and communicate with others since you don't have data and that Fizz doesn't support Wifi call yet.
    Hope it helps
    Cheers
  • Claude J. #27154
    Claude J. #27154 Posts: 146 ✭✭
    I use the app called fongo, it's pretty powerful, you get a ''voip'' number and the line is crystal clear if you have a good internet
