Technical issue - ticket got 4 weeks without solution
AbdulRahman N.
Posts: 3 ✭✭
Is there any estimation how long does technical issues take to be solved? I got one since Aug 9th in progress, and it is such simple issue, FIZZ charged my credit card ignoring a discount perk used on my plan.
Is this a clear invite so unsubscribe?
Best Answer
What is your technical issue?
The issue is that Fizz did not concider your discount perk on one bill?
Yes, that is the issue
0 -
Fizz will consider it for the next billing period
1 -
Help: internet connection suddenly really slow. Can you contact me. Thank you
0 -
You should start a new subject...
