Why if it says same price 120 mbps speed as the 60 mbps speed, for me is not the same?
Best Answer
What exactly happened? Did you downgrade your plan from 120 to 60 mbps? Please note that any change you make will only become active in the next billing cycle. So if you downgrade your plan, the speeds will only change with the next plan renewal. The new price in the plan is not reflected until the renewal date.
Also note that the 120 plan is currently on sale for 50$
1
I dont understand ? The 8$ must be the taxes right ?
Right now 120 and 60 is the same price you can changed at any time your plan if you want to take advantage of this offer
1 -
Could it be due to the fact that your rebates haven't been applied to the new rate?
