Problem LTE?
            Do you get a good signal ? What model is your phone and where are you in the coverage area ? Its hard to answer with low information on your situation. LTE is dependant on your phone, your location and other variable. Have a nice day 5 5
            And did you set the APN of Fizz to get de best of the network : https://fizz.ca/en/faq/what-are-fizz-network-settings-apn5
            Is it the firs time ?
 Try to Check your Network make it Automatic
 And try to restart your phone6
            Reboot the phone
 You can contact Fizz support by chat for help5
            Hi Estefano
 With Fizz (and Videotron), their LTE band is AWS or Band IV (which is 1700/2100 MHz). It doesn't penetrate buildings as well as, for example, 700 MHz LTE, which other vendors use a lot. As a result, the signal strength will usually not be as good indoors. If it gets weak enough, you can change your network settings to use the 3G network or Fizz EXT (for short term use).
 If you need to contact Fizz, you can Live chat with support:
 3- Open a help link page from Fizz Solution Hub: https://fizz.ca/en/faq/how-do-i-make-sure-my-mobile-service-working-properly
 4- The green chat bubble should appear after a few seconds in the bottom right corner.6
