About internet connection type inside the home! is it using Coaxial cable(Videotron)or using phone l
Hamid R. #7154
Posts: 1 ✭✭
in Internet
Hello everyone! I wanna know if internet connection inside the home using Coaxial cable like videotron or using copper phone lines inside the building like Bell, the problem for me is phone lines is so messy and so noisy! and if I try to use it for internet, the quality wont be good,
Thanks in advance for your answers!
16
It is a videotron coaxial cable. If you need a referral code here mine K61CD, in order to have 25$ after 2 months
7 -
Fizz is using Videotron's cable infrastructure. The quality is very good.8
Hey, yup as others have said, Fizz is a child brand of Videotron, they are built on the same infrastructure or a clone so it all uses the same coax lines. Most of the time, DSL (bell) lines can't handle the high transfer speeds so they are not in use for any plans above 10-15mbps.7
It's a videotron coaxial cable.5
Fizz uses the Videotron network, it’s very stable. Have had no issues, it has been very stable so far.5
