Technical Problem
in My Mobile
I tried 2 LG phones and a Kyocera phone, 1 LG finds the Fizz network but keeps rebooting all the time, another LG phone i tried keeps searching for Fizz network all the time, and it can't find the Fizz Network, the Kyocera phone also keeps losing the network
28
How old are these phones? Have they been working properly with a different provider until recently? How long ago did you activate your sim? Was a number ported over or is it a new number?17
Were theae phones working before with another carrier?16
You need to make sure the phones can run on the frequencies needed by Videotron. Older phones did not have all the bands needed.16
this phone was used until recently with Public Mobile and rogers and it worked great15
Okay, new number or old number? How long ago did you activate the sim? Sometimes the activation process takes a bit longer.15
I ported old number, and in fact it's working with Fizz but after about 30 seconds the phone reboots itself, and this happens only with the Fizz sim card, not with Public Mobile/Rogers/Chatr, I activated sim yesterday at 10 PM15
I have an old Motorola Razr flip phone that can only connect to the Fizz ext network. It keeps trying to connect to something and I am assuming it's the Fizz network but can't. It will do this for about 10-15 minutes on restarting, beeping the whole time, then stop and just stay on the Fizz ext network. I can make calls and send text. This doesn't happen with Rogers. I think these old phones are reaching their expiration date.15
That's unusual. I haven't heard of that problem before. You can make and receive calls and texts? Use data? Just that the phone keeps rebooting? I can't see why changing a sim would do that to a phone, but I suppose it's possible.15
Hi Allison, I am assuming you're asking me that question. The phone doesn't reboot. It just keeps trying to connect to another network. This only happens when I first turn on the phone and goes on for about 10-15 minutes before and stops and everything is fine. It happens on two motorola razrs.14
Might not be compatible with fizz's network14
