HSDPA 850 / 900 / 2100 & CDMA; TD-SCDMA are supported. Will my phone work with Data and Calls?
Mark M. #525
Messages 2
My phone's supported bands are:
2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3G bands HSDPA 850 / 900 / 2100 & CDMA; TD-SCDMA
4G bands LTE band 1(2100), 3(1800), 5(850), 8(900), 38(2600), 39(1900), 40(2300), 41(2500) Will it work with Fizz (Data and Calls?)
7
Without Band 4, you will not get LTE data.
https://fizz.ca/en/faq/compatible-devices6
Which frequencies must my phone support?
For an LTE-compatible phone configured with LTE network preference:
Calls: The device must absolutely support the frequency HSPA 850 MHz or 1900 MHz
Mobile data: The device must support the dual-frequency 1700/2100 MHz (also called AWS or band 4) or 700 MHz
For a phone that only allows 3G or HSPA preferred:
Calls and / or mobile data: The phone must support the 1700/2100 MHz frequency (also called AWS)
Cheers
7 -
Will it work with 3G internet though?
Thanks!6 -
It wont be reliable only one frequency supported!7
I don't think it will work with 3G data either, since it doesn't have 1700/200 in 3G either.8
Yep I agree with Allison!7
You must have 1700 to be able to fully use your phone in this network.6
