MMS problem (SMS images/pictures) SOLVED ?
If you have problem sending MMS, check if you have a “bearer” setting in your APN config on your phone.
Try to Set bearer = LTE
If MMS work after that, I suggest you split your APN config in 2:
1. Login to Fizz.ca
2. Go to: Overview \ Manage \ Advanced Parameters \ Fizz network parameters
3. Click “resend me the notifications”
4. You will receive 2 SMS configuration messages: click install on both
5. Then, on your phone, go to APN settings for FIZZ MMS (on my phone: settings \ More networks \ Mobile networks \ Access Point Names \ FIZZ MMS)
6. Set Bearer = LTE
Note: I think it’s just a temporary FIX as MMS will only work if you have LTE (I think so, not sure)
Bienvenue!
Manual config (create 2 APN):
APN: mobile.bm
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 500
Authentification type: Not set
APN type: default
APN protocol: IPv4
APN roaming protocol: IPv4
Enable/disable APN: checked
Bearer: Unspecified
Mobile virtual network operator type: GID
Mobile virtual network operator value: 55
APN: mobile.bm
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mms.mobile.bm
MMS proxy: mmsproxy.mobile.bm
MMS port: 80
MCC: 302
MNC: 500
APN type: mms
APN protocol: IPv4
Bearer: LTE
7
Tanks for the info. Very useful. ?3
This post should be sticked to the main page!3
Since I don't receive the configuration messages neither from Fizz or when I do it from my account, would you mind sharing screenshot of this dual config?3
Thanks a lot!3
For me the only thing that worked was when I changed APN type to "default,supl,mms"
That small change allowed me to send MMS. The system will not send me the 2 SMS configuration messages.2 -
@ SergeLa: I already tried to set APN type to "default,supl,mms" but it didn't work for me.
Probably that Fizz have tons of SIMS card pre-configured with videotron APN and they decided: « instead of ordering new SIMS card with good APN, let’s send them to our client's and ask them to manually configure their APN. » Bad business decision. It seems there is no single configuration that fit all phone model.
3 -
Charles you are a genius! After 2 mounts of trials and errors on my own and some "Fizz support" I finally have MMS working using your 2 files configuration. Thanks a lot!
And me too the "default,supl,mms" did not work.3 -
Wow, I am glad it is working for you. I find it very weird that it takes so many different types of APN. Good find from Charles Hebert!2
My mms don't work and I don't have bearer settings on my cell...
I have LG5..
Do you have a other option?2 -
WOW! thanks a lot! it's worked I can send picture again3
Wow enfin ça fonctionne, merci!2
Doesn't seems to fix the datestamp issue that I still have, but seems to be very helpful for many of you! Thanks1
